How do I get my phone connected?
Hymn8969
@Newphones wrote:
I have VPN under the settings and more, how do I connect with that?
@Newphones  Good question I'd like to know too...why not start your own thread. You'll get dedicated answers to your query and get to pick the best solution. Go to the phones and hardware section and enter it in the "ask a question " bar.
Newphones
totalUser
Is your phone locked?
Try sim in different phone that works with public mobile
Triguy
If you are asking about data then you need to configure APN settings.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
geopublic
darlicious
@Hymn8969  Connected How? Activate an account? Calling? Data?
