Reply
Highlighted
Re: How can I print my monthly statement?
How can I do post paid?It’s difficult for us to get monthly statement!
Highlighted
@676672471
If you need a detailed invoice on a regular basis, to have it reimbursed by your employer or for tax purposes for example, and you don't want out deal with Public Mobile's process and wait times, you would need to sign up for a postpaid plan with a second or first tier provider. In the Telus group that is Koodo or Telus. Signing up for these kind of plans will require a credit check. The fastest way to sign up would be at one of the according provider kiosks, or at places like WOW or TMS.
As mentioned above, this being prepaid,  provider, invoices issued by Public Mobile will most likely not be accepted as proof of residence.
If this is a one off and you want to stay with Public Mobile for the savings, you'd be better off finding an alternate means to make this work. A conversation with the person /institution that you need this for might be in order, I'm sure you are not the first and not the last one in this situation and if you explain things people are usually happy to help.
Highlighted
If you have a credit card bill, bank statement, property tax bill or anthing like that which got mailed, that should be good proof for most.
