08-22-2015 02:45 PM - edited 01-04-2022 01:56 PM
Hi i have an iphone5c but the celluar data doesnt work for my new pb sim i got the 1gb plan unlimted text and call,the call and text works but the cellular data doesn't.
09-04-2015 07:00 PM
Here's another set, MUCH MORE detailed:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
ALSO, Here's the Tethering APN Settings As Well:
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Welcome to Public Mobile
Enjoy
09-04-2015 06:57 PM
Hi The post by Adamay007 definitely works, I just setup my iphone 6 3 days ago using the APN setting.
08-25-2015 11:13 PM
08-25-2015 12:13 PM
08-25-2015 12:02 PM
@AdamAy007, Does this site also have APN Tethering Settings as well?
08-25-2015 11:12 AM
08-24-2015 09:19 AM
Follow these steps here:
To access data, follow these instructions to change your APN settings:
1. Insert your Public Mobile SIM card into your unlocked iPhone.
2. Tap “Settings”
3. Tap “Cellular”
4. Tap “Cellular Data Network”
5. Change your APN values to match the table below:
*Only update the fields that are circled. Leave every other field empty
08-22-2015 02:49 PM
MORE THAN LIKELY, APN (Access Point Name) Settings is NOT set to PM's settings
I have 0 Experience with Apple iPhone
Can anyone with Knowledge on this please Guide @braddimilo?
08-22-2015 02:47 PM
Be sure cellular data is turned "on" in your settings and that your apn setting conform to this post: http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartph...
