03-08-2019 03:35 PM - edited 01-05-2022 06:49 AM
Can a public mobile sim card and plan be used in a GPS tracker both in the US and Canada?
Could my wife track me if I'm in the US and she is in Canada?
03-08-2019 05:04 PM
03-08-2019 04:22 PM
@Bass note that @Someone_here is correct. For a GPS tracking app to send your current location to your wife, you would need a data connection. If you don't purchase a US Roaming Data add-on, the app will be unable to send any location updates other than when you are connected to a Wi-Fi network.
03-08-2019 03:41 PM - edited 03-08-2019 03:41 PM
I guess you would have to try first in Canada if it works in your GPS tracker.
If yes, then a 10 day US data add-on would be required for the tracker to work as well in the states.
