Reply
Highlighted
Dropped calls driving me bananas!
- Have iPhone 7 plus with latest software
- Switched from Telus to Public 1 mo ago
- Have reset network settings multiple times
Since switching, my calls drop ALL THE TIME with public mobile, with seemingly no rhyme or reason! Sometimes the calls last an hour, other times only a minute or two before dropping. I was on a call with a key client 2 weeks ago and it dropped so much I had to use my kid's phone, super embarrassing. It didn't do this with the Telus SIM, ever. Same cell tower. HELP!
Accepted Solutions
Highlighted
Re: Dropped calls driving me bananas!
It happens with some accounts...Smiley Frustrated you need to reach the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and they will help you with this problem . Be patient usually the waiting time is few hours to 2 days.
All Replies
Highlighted
Highlighted
Highlighted
@northernbcguy  Please note that even though PM uses the Telus network it's not the same service as Telus because Telus uses Voice over LTE and PM uses 3g for voice calls. Telus is a Tier 1 provider and maybe a better choice for business purposes.
Highlighted
But doesn't PM actually use LTE that has been throttled down to 3g speeds?
Highlighted
@ipkonfig  Yes they do but that is only for data.
Highlighted
A quick and dirty fix is to set the phone to do 3G only, and see what happens.  Let me know if it works
Highlighted
Worthwhile experiment, but did'nt work for me. Robot Sad
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
When you are in a call, you are already forced to the HSPA+ network for the duration of the call.  I had a dropped call a couple of days ago and I already had LTE connections disabled.
Highlighted
Somebody from Telus should be fired for this debacle.
I can't believe it's still not fixed!
