12-26-2017 01:25 PM - edited 01-05-2022 03:49 AM
I am suppose to get 6gb on one plan and 4gb on another plan and it has not reset since October I have come to find out. Should my plan not reset each and every month so I get the full data?
12-26-2017 08:13 PM
@UrbanArt was your plan a 90 day plan, or was it a 30 day plan with 3G-speed data, by chance?
12-26-2017 02:08 PM
No problem. Hope that helps. If it’s a different issue try contacting a moderator and they can look into your account for you.
12-26-2017 01:51 PM
Thanks.
12-26-2017 01:48 PM
Public Mobile primarily deals in 90 day plans. Sounds like you probably signed up for one. The data allotment quoted for those plans are for the full 90 days. So you get it all up front and use it as you wish until your next renewal date.
Maybe check your plan under my account to confirm what plan you signed up for under plan details.
