Data is not working with my iPhone 8 Plus
jabiscusss18
Hi
my data is not working on my iPhone 8 Plus
i purchased a sim yesterday afternoon and it still isn’t working. When I log into my account it says active. Does anyone have any suggestions on how to fix this?
11 REPLIES 11
Jarvar
Welcome to Public Mobile @jabiscusss18
I didn't see if you mentioned whether or not calling and texting was working with your account yet.
Is this a new number or a port over from another carrier?
Sometimes you might need to check the carrier settings
General->About->Carrier
Also turning on Cellular Data, LTE and Roaming could help.
Cellular->Cellular Data Options-> Enable LTE and Data Roaming
Network Selection-> Automatic
Give those settings a try and report back if it still isn't working and we'll see how we can help further.
I'm sorry to hear about the trying experience right at the beginning.
dwil
Hi
You need to set an access point name (APN). On your phone
  • Settings > Cellular > Cellular Data Options > Cellular Network
  • or
  • Settings > Mobile Data > Mobile Data Options > Mobile Data Network
You may need to restart your phone. If you update your IOS version you may need to put these in again. Good luck
The APN info is case sensitive, so if there's a Capital letter use it.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Carld123
Try resetting the network connection..
jabiscusss18
I haven’t used any data what so over. It says 4.3 gb available. I went to the store I got the data and sim from and my data works in another phone. So it’s definitly my phone that’s the issue 😫
@jabiscusss18, can you screenshot your overview screen, and your usage history?  It seems like it’s possible that you may have used all your data in just a couple days..
im not sure if what the previous screen shot is showing is correct, or a display error.
jabiscusss18
The 40 dollar plan with 4 gb. I can phone and text. Just data is not working
jabiscusss18
will13am
@jabiscusss18, what plan did you get?  Does the account show the proper features in the plan?
jabiscusss18
No it’s not
it says I don’t have an add on?
Carld123
Call and text works?
