06-04-2019 01:13 PM - edited 01-05-2022 07:40 AM
I would like to start by saying that I’ve been delighted with the service from Public Mobile for over a year now. My data has been working perfectly until I purchased a US Add-on.
06-04-2019 02:50 PM
@Nichlee Go to Settings --> Cellular, and then Make sure Cellular Data is enabled (green background). Turning Roaming On under Cellular Data doesn't hurt either. Also, when you do a network reset you have to re-enter your Wi-Fi passwords..
06-04-2019 02:49 PM
I think you're right. I'll put in a message to them now. Thanks
06-04-2019 02:49 PM
Yes, I did turn the roaming off and WOW is there ever a lot of info here, thanks. So far, I'm still stumped.
06-04-2019 02:48 PM
I don't have another phone to try this, but that's a good idea.
06-04-2019 02:47 PM
Thank you, it was definitely worth the try, but it didn't work I'm afraid.
06-04-2019 02:22 PM
@Nichlee I recalled some customers had the same problem after the US roaming addon. It is the problem on PM side. Maybe you need to contact the Moderator to help to reset your phone on their side. You can simply click on the Envelop icon and send to "Moderator_Team" and tell them your issue. They will reply within 2 days.
06-04-2019 02:18 PM
@Nichlee wrote:I did go to the States and it worked intermittently through Washington and Oregon. Now back in Canada, I don't get any data at all and the 10-day add-on has expired. Everything worked perfectly until I added the US data.
Can you try your sim in adifferent unlocked phone?
06-04-2019 02:12 PM
06-04-2019 01:38 PM
The above answers have good advice.You could also try doing the lost/stolen phone trick to re-provision your plan features.
1. Login to your self-serve account.
2. Report your phone lost/stolen using 'Plan and Add-Ons' --> 'Lost/Stolen Phone'
3. Log off
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to enable all features of your plan again.
06-04-2019 01:27 PM
06-04-2019 01:24 PM - edited 06-04-2019 01:30 PM
Did you make sure that you turned off roaming ?
Here is an article about troubleshooting.
https://appletoolbox.com/2013/04/iphone-could-not-activate-cellular-data-network-fix/
