“Change my plan now” not highlighted
LM97
I changed plan but can’t complete the transaction in my acct because when I click on “Change my
plan now” it does not respond because it’s light grey ahowing so it’s not highlighted to accept my change.... what can I do?
stonechucker
@LM97, are you trying to go to a cheaper or more expensive plan?
If cheaper, fully top-up the base-plan cost (ie $40 for a $40 plan), then go back to change plan and try to change the plan.
What is your current plan status?  Active/Expired/Suspended?
@LM97- Usually that type of problem would be due to the browser.  You can try another browser, or use your browser in privacy/incognito mode (or clear browser cache, etc.)  That said, are you sure you want to do an immediate change?  if you do, you will loose whatever is left on your current plan.  Also possible... do you have sufficient funds for the new plan (assuming you don't have a CC on file)?
missorange
Try using chrome-incognito to try again, sometimes it is very slow in the self account. if still cannot make the changes, maybe need to contact the MOD team.
geopublic
@LM97  Logout, clear your browser's cache and try using incognito mode when accessing the selfserve site.
