Cellular Connection is Down.
Heavyrocker
I have 2 gigs of data and just cant seem to connect within the last 5 hours,is PM shut dow?
11 REPLIES 11
Heavyrocker
UPDATE:
All working now,it seems i had my data usage setting set to low,i have 1 gig left and i set it shut off at 30MB
Chaos_Scorpio
Are you underground or in an elevator? Or somehwere else that blocks communications?
Where are you located, are you in service range?
pchan
1) Check if your settings are correct for your phone. This site has a lot of good information that covers a large number of phone bands.
https://apn-canada.gishan.net/
2) Completely reboot your phone
3) If it doesn't work check if there isn't a os or firmware update.
4) Lastly if the above doesn't work reset all network settings. You will likely need to reconfigure the phone so make sure you know how to do it (use google).
Goodluck
youbme
Hello @Heavyrocker, it certainly sounds like an issue with your phone. What model phone are you using (more details the better)? If you haven't resolved the issue by reseting your APN settings, let us know and we help you troubleshoot your particular phone model.
will13am
Apart from making sure the APN configuration is correct, check that mobile data is turned on.
SD08
As Ndesai mentioned, check that your APN settings are correct.  You can do that by following the instructions here:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
@Heavyrocker wrote:
Did all that,i switched the sim card into my other phone and i have connection,something is wrong with my new phone settings or something
Make sure you have the correct APN settings.
Heavyrocker
will13am
Try rebooting the phone.  Maybe that will reestablish the data connection.
Heavyrocker
I checked,i have 1.5 gig remaining
NDesai
Did you get a text? Check in your self-serve account and see if you have used all up.
