Reply
Can't send txt messages
Hi All,
I recently switched to an Iphone 6S, everything works fine except I can't send out txt msgs...I can call out...receive calls and receive txt msgs, but, I can't send out txt msgs...I keep getting a failed sent msg..can anybody help me solve this issue??
Re: Can't send txt messages
@rustynailzfrank wrote:
Hi All,
Not being much of an Apple guy but perhaps you need to set the messaging program to SMS and not just iMessage.
Hi All,
@rustynailzfrank  That sounds like a settings issue with your phone and/or text app. What type of phone do you use iPhone or Android. Make sure you've cleared the cache of your texting app. If you are using a third party app try using the phone's native text app.
I do have iMessage off...cos I know it has nothing to do with regular sms txt messaging...I know it has to be some kind of setting...but, not sure what it can be
Iphone 6S
Hi All,
How about what plan are you on?
If the $10 plan then maybe you've used all the texts.
$15 plan...unlimited outgoing/incoming text msgs
Iphone 6S
@rustynailzfrank  Yes, is getting late I missed that you mentioned it in your original post.
Do you have another phone to test with? In the past some customers reported that when switching phones texts started working on both phones.
If you don't have another phone put the iphone in airplane mode for about 15 minutes and try again.
I will try the airplane mode for 15 mins...do I turn off the airplane mode after the 15 mins?
@rustynailzfrank  Yes, turn off airplane mode and once it connects back to public try sending a text.
