Reply
Highlighted
Can't make or receive calls.
Help... Everything works but I can't make or receive calls. Just signed up.
Accepted Solutions
Highlighted
Re: Can't make or receive calls.
Changed it again today just to try something New.
All Replies
Highlighted
Did you port a number over or did you pick a new number?
Highlighted
New number
Highlighted
Highlighted
Changed what again?
Edit: Maybe "it" is your number. What exact make/model of phone is the SIM in?
Edit again: You marked your post as the solution. Did whatever you did get you going?
Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
See what happens.
Highlighted
Just tried what you suggested but it didn't work unfortunately. The sim is in a Moto G3 xt1541 from London.
Highlighted
According to willmyphonework.net it is not compatible with Public Mobile. You can barely do some data but not voice.
Highlighted
REALLY... Wow when I checked the IMEI number on the site it said it was compatible. Glad I didn't get a big plan and ported my old number. Thanks a lot for your help. I really appreciate it.
Lots of people are losing money because their site is claiming phones are compatible when they really aren't.
Not cool.
Thanks again for your help
Highlighted
Not cool.
The IMEI seems to only really check for blacklisted. And it does sorta kinda work as it does do 4G LTE which is what the data runs on here. So maybe if you're just looking for data then "well sure come on in that'll work here". 🙂
Highlighted
@AJ2 yes you have fallen prey to the #)(@*#ing inaccurate IMEI checker on PM's site.  Yet another victim.  But looking at the xt1541 spec on gsmarena it is definitely not compabible, since it only has the 900/2100 MHz 3G frequencies used overseas and not the 850MHz/1900MHz used by PM (and Koodo, Telus, Bell, Virgin, Lucky).  Your phone will work with Rogers, Fido, and Chatr, since Rogers still operates a compatbile 2G GSM network, but they are shutting it down at some point in the not-too-distant future (I think in 2020 sometime).
EDIT:  @Alan_K @Brooke_C @Dave_M I'm tagging you yet again to complain about the broken IMEI checker.  It keeps claiming victims and you need to do something about it.  Please.  I'm begging.
