Can i text Public Mobile even tho my cell connection is out?
Heavyrocker
15 REPLIES 15
Heavyrocker
All is ok now.
Moid_I
Retraité / Retired
Retraité / Retired
@Heavyrocker Can you let us know if you are getting serivce on the phone?
Aww, that's good. At least your phone is now functional
Heavyrocker
I found the problem,i just had to reboot the thing for an update.
NAH, IT WAS SOME OLD PHONE WITH A VICE-GRIP that broke the Connection, LOL
Heavyrocker
Proberly a bird pooed on a circut wire.
Heavyrocker
Just tried my WIFI....im down and out,first time in years.
Perhaps Towers in your area are misbehaving.
No prob.
If my Reply answered your inquiry, feel free to accept as solution, and bravo me if you wish
Heavyrocker
Looks like ill have use a phonebooth...thanks.
More than likely NO.
Try WiFi and see.
If NOT, Then you require Signal to send Text
Luddite
Don't see how, but give it a go.
Heavyrocker
My payments are up to date,must be an ioslated issue,thanks for the response.
@Heavyrocker, As far as I am aware, Network is still kicking. Maybe isolated issue
Heavyrocker
As of this evening it says""network not available''   is public mobile down?
