Can I use my PM as a SMS gateway?
arahmanfahad
So the title says all.
Can I use my PM SIM as an SMS gateway? as I have unlimited international text, so I was asking can I use it
Jessiecups1823
Yes you can works just like the other mobile company’s
@arahmanfahad wrote:
@ChuckYeah  It's like I will use my PM SIM as a gateway, so if any user wants to send SMS, he will use my website and the SMS will be sent from my SIM.
Kind of free texting service.
 I had never heard of it. Thx for the education.
arahmanfahad
geopublic
@arahmanfahad  Sure knock yourself out of if it works. SMS gateways usually used 2G networks. If the one you use works with 3G or LTE go for it.
ChuckYeah
I'm not 100% sure what an SMS gateway is...? But I read about it on Wikipedia and it sounds like what I do with the Mighty Text app. If you don't find another solution, you might look into that. Your phone and SIM have to be in Canada though.
