12-14-2019 06:22 PM - edited 01-05-2022 10:01 AM
Hi I have a friend who has a 437 number and I can’t seem to dial them. Who should I contact for his problem?
12-15-2019 07:45 AM
I encountered that problem too.
Sometimes, I don't know why, other area codes are tricky to access.
Try to add a 1 or a +1 in front of the phone number. That should solve your problem
12-14-2019 06:54 PM
@Dehe48...I've been noticing lately that when I dial a number, it can be several long seconds before the number rings. I'll dial then nothing but dead air....then after about 10 or 15 seconds it finally rings. Maybe give it a little longer before abandoning the call.
12-14-2019 06:31 PM
@Dehe48 Check to make sure you have the correct number.
12-14-2019 06:23 PM - edited 12-14-2019 06:24 PM
@Dehe48 wrote:Hi I have a friend who has a 437 number and I can’t seem to dial them. Who should I contact for his problem?
That's a Toronto area code...should work fine. Can they call you ? Can you text them ?
Try dialing 1 437 then the number.
