Reply
Highlighted
Re: $15 Plan
Greetings,
I just wanted to emphasize again, a great thing about Public Mobile:
Public Mobile automatically stops a limited-usage service once you have used it all up.  Once you have used up all the call-minutes, data, or texting in your plan for a billing cycle,  you won’t be able to use that service anymore until your plan renews or you purchase an add-on.
This is a great thing, as you will never “go over” and get overcharged.   Robot Happy
Highlighted
Re: $15 Plan
Great!
Highlighted
Re: $15 Plan
Makes sense. Thank you.
Highlighted
Re: $15 Plan - how do you get data?
Hi all,
I have a follow-up question to this.  The $15 plan mentions 250MB of data with AutoPay.  How does one actually get that data?  Do you have to wait for a couple months to go by?
Thanks!
Rob
Highlighted
Just set up the autopay and data will be activated
Highlighted
It is automatically added to your account once you setup autopay.
Highlighted
So even if you have done no referrals and a month hasn't gone by, you still get it right away?
Highlighted
When you set up Auto Pay, you get the data instantly. No referrals needed.
Highlighted
 with auto pay u get the 250mb
Highlighted
Login to your Self-Serve and check usage... any Data you will get (and any Data you have used) will be shown there.
