Reply
Highlighted
$15 Plan
Dear Members,
I have $15 plan monthly plan for my public mobile.
The plan detail mentions - "Unlimited  International Text and Picture Messaging". But no information is provided about Local text messaging, that is messaging within Canada. Is local messaging as well unlimited/free?
Thank you.
Best,
Vivek
Accepted Solutions
Highlighted
Re: $15 Plan
Yes everything is included and unlimited from anywhere though happen to be in Canada with access to Telus network to anywhere in Canada
All Replies
Highlighted
Re: $15 Plan
Highlighted
Re: $15 Plan
Vivek11 yes it most definitely is!!
Highlighted
Re: $15 Plan
@Vivek1  yes all text  are free as long as you're in Canada
Highlighted
Re: $15 Plan
@Vivek1  Unlimited International texting means that you can send  and receive texts to and from anywhere in the world (including Canada) as long as you are in Canada.
Highlighted
Re: $15 Plan
Yes, all messaging is free with this plan. Just make sure they originate in Canada.
Highlighted
Re: $15 Plan
If a service is not included in you plan, it will just don’t work.
Public Mobile is prepaid, you will never get other fees if you don’t buy add-on.
Highlighted
Re: $15 Plan
Hi Vivek,
As long as you are sending message within Canada, the plan you are having is allowed you to send unlimited Text and Picture message to anywhere.
Daniel
Highlighted
Re: $15 Plan
Thank you so much for your response!!!
Highlighted
Re: $15 Plan
@Vivek1
You do need to configure your APN Settings for Public Mobile and have Data (or WiFi) Enabled to send and receive MMS attachments. They do use Data connection but they don't use any billable/measured Data (meaning they don't consume any Data Add-ons you might purchase, no Data is provided in your $15 Plan).
Without active data connection you'll only see "click to download" placeholders. The Telus network will store attachments which haven't yet been received (acknowledged with a receipt), but I don't know how many msgs can be stored or how long they can be stored before they're "lost" (deleted by the system).
