How to distinctly show remarks from a previous post
bluejaywpg
How do you put previous remarks from an earlier post beside a vertical line - similar to an email?  See attached screenshot:
bluejaywpg
@ShawnC13 Thanks for including that link to the post.  Maybe I'll revise that post with pictures.  I actually find it more confusing than the non-pictorial explanations that you & the others provided.
bluejaywpg
@gpixel wrote:
@bluejaywpg you need to be on a desktop browser
there is an option above the top right corner of the reply box. if you click (expand toolbar) you'll then see " in the top toolbar
@gpixel & everyone else thank you.  I did hit that 3 dots button but never thought to hit the " button.
ShawnC13
That is the quote feature.  If you are on a mobile device it won't work.  On a pc hit the ... at the end of the row with the font customizations and a second row will appear.  Then you will hit the " marks in the top row and that will quote the post you are responding to
ADDED Link to Thread with pictures
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Quote-and-Macros-button/m-p/513465...
gpixel
