Reply
Re: iPhone Update and APN settings
@joko wrote:
tfyh,
where is a moderator located? how do I get that going
Hopefully everything is working now.
How to set data on iPhone 5c.
Hey @VC009
You should get a carrier update from Public mobile.
Cheeck for update in settings > General > About (thanks @Luddite).  If no update, go to Settings > Profiles and delete all old profiles.  Then check for update... you will receive the APN settings as part of carrier update.
@imm1304 FYI:  Settings > General > About to get carrier update
>>> ALERT: I AM NOT A MODERATOR. JE NE SUIS PAS MODERATEUR.
My cellular settings page looks different . Can you help me
Re: iPhone Update
I am having the same issue, did you get your phone to work?
Re: iPhone Update
What kind of phone is it?
I am having the same issue with the same phone.  was this ever solved for you??
Re: Data on iphone 5s doens't work....
I have I have been trying to get data housing on my 5S for over a month. I’m interested in your workaround if still available. Thanks.
Are you having trouble with your apn settings?
