Reply
Highlighted
Re: Top Contributors - August 2019
Thank you @GR
To confirm, no way to tell my current status or rank unless I recieve the badge?
Highlighted
@samanthaburton you can click on your user name and you'll see all the info about your community account!  I just did and I see you've got some badges for bravos given, 1st post, 1 reply given and a few others but none yet for the community.  Keep in mind you have to help quite a bit in the community to get in the top 50% or better
Highlighted
@samanthaburton wrote:
Thank you @GR
@samanthaburton  With some experience, you can estimate, but it's hard to be sure which contributor level you've achieved for any given month until you actually get the badge, which is usually awarded around the same time as the monthly contributors announcement.  That's because the same amount of contribution can result in a different reward level from one month to the next, depending on how busy the month was.
Highlighted
Thank you @GR
You can kind of go with Bravos leaderboard.....
