Reply
Highlighted
Re: System maintenance - On November 10th 2019, 00:00  ET - November 10th 2019, 10:00  ET
Thanks for letting us know.
Highlighted
@meeyahpot wrote:
Thanks for the update. I also need help as I was trying to make a payment on my account but my visa debit is being declined. All my infos were all correct but still doesn’t work
Did you find a solution to your visa debit issue? If not you should create your own thread under paying for service.
https://productioncommunity.publicmobile.ca/t5/forums/postpage/board-id/paying_for_your-service
Highlighted
I don't think the maintenance is causing it because it hasn't started yet. Is it working today if you buy something else?  If you need a payment done today, you can buy a voucher at a store.
Highlighted
if i port a number on the weekend after hours will the port go through?
Highlighted
@station1104It is likely that the system maintence only deals with the billing system. You should be fine as long as you can submit before the maintence starts.
Highlighted
Still not accessible as of 16:20 EST (4:20 PM). I'm on the west coast.
Highlighted
Self Serve and the activation site are working fine (except for some promotion section of the self serve site).
Highlighted
I'll try again...maybe I need to empty my browser's cache as it can sometimes prevent a site from refreshing.
Highlighted
I tried again just now but still unable to access the self-serve section of the site out here in British Columbia. Current time is 1:48 PM PST (4:48 PM EST).
Highlighted
Finally able to access self-serve. I dumped my browser's cache and restarted it...not sure if that's what made the difference. Anyway, all seems back to normal again.
