Reply
darlicious
Re: System maintenance - On February 2nd  2020, 0:00 AM ET – February 2nd 2020, 10:00 AM ET
@Twells  Sometimes an autopay fail is caused by a downgrade in plan. If you do so manually adding funds to your account to cover the cost will avoid the autopay fail from happening on that cycles renewal.
    I advise whenever you are making any changes to your account to clear your browser and use secret/incognito mode. It just makes the system so much happier to work with you rather than against you.
daryl604PTM
That is absolutely very concrete info.  The online system likes to work with a clean slate, less confusion.
timnoj88
Much appreciated for the heads up.
Z9999
Hi dear, I activated another phone around February 1st  . But I didn't get any Refer a friend rewards.  I did put my code there and the system showed available.  What I can do now?  Thanks.
Tags (1)
gblackma
@Z9999 could you please elaborate ? Did your friend refer you?  Did you enter your referal code at activation? And exactly what do you mean by this?
Z9999
Thanks.  Sorry my English is not good.  This is the 3rd pone I activated at public mobile.  Yes I did Ienter the referal code at activation. But I didn't get any rewards.
gblackma
Thanks for answering @Z9999 . To get your sign up bonus, the account holder of the 3rd phone has to contact a moderator and ask them to apply it. Click on the green questionmark in the white circle at the bottom right of your screen.  This connects to the autobot Simon.  Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket ). Will need the phone number and the referral code of the person that referred them. If you are unable to contact them that way, private message them using this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Z9999
 I sent private message . Thank you very much .
gblackma
You are welcome @Z9999 . Have a great weekend .
Z9999
