Reply
sheytoon
Re: Wireless Outage
I'm not sure yet. If I have any info that can be shared, I will do so.
crystalstjean19
Re: Wireless Outage
My voicemail is acting up too i cant delete
Re: Wireless Outage
I got a VM alert, called and entered the password,  the dead air..  I guess they have not fox everything yet
S--S
Re: Wireless Outage
@crystalstjean19
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Check your voicemail messages (publicmobile.ca) and pressing 7 to delete..
[Service Status Update] The outage impacting customers in Ontario and Quebec has been resolved. Please consider rebooting your device(s) if service isn't back yet. Our apologies for any inconvenience and thank you so much for your patience!
christyj4
Re: Wireless Outage
I do not have data in Manitoba. Has anyone heard of any outages there
Re: Wireless Outage
yes Telus said the outage affects Winnipeg area
https://mobile.twitter.com/TELUSsupport/status/1445884017056706563
z10user4
Re: Wireless Outage
 @christyj4 : Maybe. Did you get a "message" from your phone saying something about the connection?
Try a restart. Then try switching to HSPA/3G.
christyj4
Re: Wireless Outage
I will try a few things.
hari_pm
Re: [Resolved] Wireless Outage
says resolved but i'm still just "searching" no network
@hari_pm   did you try reboot your phone?
If still fail, try to re-seat your SIM
