Reply
LP1
Re: [KNOWN ISSUE] Select customers affected by slower renewal process
You could read the first post and My posts to try fixing it.
LP1
@yvonnesmith wrote:
My plan expired yesterday and I topped it up this morning and I can't make or receive calls or send or receive texts and I want to know when this problem will be fixed
Did you read recent posts in this thread?
Try the lost/stolen feature.
Failing that then try the extra $1 manual payment.
My account says active but I can't make or receive calls or send or receive texts
Good to know. Did you try the possible solutions?
I tried the lost/stolen and it didn't fix the problem
Did you follow all the instructions for the lost/stolen trick?
If so then carry on to the $1 trick. That's where you manually pay a $1 into your account and then restart your phone again.
Moderator
Hi @yvonnesmith
Please send us a private message with your phone number and PIN to have this issue resolved.
Thank you!
Ashley
Public Mobile
Hey @ShawnC13
Great question. Unfortunately, if a customer is expired, they won’t be able to purchase an Add-On, even if they were to contact our Moderator Team. You account must be active and have the required funds to do this.
Again, we apologize for any inconvenience this may cause.
@LP1 wrote:
If I have another emergency on my Bus and my cell texting does not work someone could die.
@LP1 I'm glad you got your service back up and running using the $1 manual top-up trick. I wanted to touch on this statement of yours that I have quoted:  you can always call 911 from any mobile phone provided it can get a signal.  You do not need to have an active plan with a carrier to be able to call 911.  As long as the phone has some charge in the battery and can get a compatible network signal, you can call 911.
For reference:
http://www.rcmp-grc.gc.ca/en/news/2017/8/rcmp-remind-citizens-deactivated-cell-phones-can-call-911
I topped up my phone this morning it expired yesterday I topped up this morning and my account says it's active but I have no data and can't make or receive calls or make or receive texts
