Reply
Re: $10 ready-made plan expiring July 16
@GinYVR wrote:
@Bell3Lucky?
With no ability to add data. No thanks.
I just switched from speakout. 100mb data addon costs $10 on top of top-ups, the $15 plan with PM with autopay gives 250mb free plus network is on telus/bell coverage as suppose to rogers, which not as good in rural areas.
Too bad PM has decided to do away with this plan.  As others have said, this really was a convenient plan for anyone who only uses their phone occasionally and being able to add on extra minutes/data made it that much better.
Additionally, it was ideal for family/guests visiting for short stays which allowed them a cheap alternative for them to have access to minutes/texts when outside of wifi enabled apps.
Definitely sorry to see this one being phased out.
Pm is better
Unlimited incoming
More than double the data
Much cheaper per minute (1c after you go over,a opposed to 25c or even more per minute)
Did I mention Canadian minutes and no roaming charges outside of your area, 711 would charge 35 long distance or roaming charges on top of the regular 25/min charge)
And better connection
All that for 5 extra on base and absolute no other charges if you keep under 100
You are a winner definitely
Welcome to pmSmiley Happy
Edit I hope you noticed 500 mins for 5 addon that pairs great with that plan. The minutes never expire as long as your account exists
Thanks for the heads up. This was a great plan. Please consider adding these limited use plans again in the future.
what is that?
I don't really understand how to use it.
@2493599588  hi what is it you don't understand?
Please read the OP carefully.
Although the title says the $10 50/50 plan will be expired on July 16, but you have only until tomorrow July 15th 2019, 11:59 PM ET, 9.59PM MT, 8:59 PT to activate your plan or schedule plan change.
In other words, if you are new and just got a new PM SIM or if you are already with PM but in either case you do not have this $10 plan, you have until midnight tonight to activate this plan or switch to it.
For new customers, you simply select the plan as part of the registration process. For existing customers, you have to log into Self-Serve and choose to change the plan. You can either have the plan take effect immediately (where you lose the balance on your previous plan) or you choose to switch to this plan the next time your phone renews; all part of the plan change process in self-serve. Just log in and click the (Change Plan) button on the (Overview tab (main default page) then select this $10 plan, then choose when to activate it.
Did you wait until 1am ET to post this? Smiley Happy
Monday Jul 15 11:59pm ET
