03-13-2017 07:58 PM - edited 01-04-2022 01:35 PM
Wondering if it is possible to keep the plan and port the number to another carrier. Replace existing number with a new number from PM.
03-14-2017 12:07 PM
I am pretty sure it is possible, whether they are willing to make the exception is a different story.
03-14-2017 01:20 AM
03-13-2017 10:33 PM - edited 03-13-2017 10:34 PM
@rkoza wrote:Wondering if it is possible to keep the plan and port the number to another carrier. Replace existing number with a new number from PM.
@rkoza, why don't quietly send a private message to a moderator and ask nicely whether they will allow you to set up a new account and have the plan from the old account moved over so you can port the number. This is obviously a big favor and so, there is absolutely no guarantees that you won't be ignored.
03-13-2017 09:23 PM
@rkoza unfortunately that's correct.
03-13-2017 08:50 PM
@SDO8 wrote:No, the way their system is currently designed, each PM account can only carry one phone number.
Is your PM plan a promo plan that's no longer offered, or a currently available, in-market plan?
If it's the latter, then there is one way to achieve what you want. 1 or 2 days before the end of your current plan, port out the number to the other provider. The PM account will cancel itself. Be sure you do this before the plan actually expires, as a number can only be ported from an active account. Then simply start a new PM plan with a new PM number. This will require having a new PM SIM in hand, as the previous SIM cannot be used again. The problem with this is, you'll have to wait until the current plan is nearly expired.
Yes it is one of the Promo plans and that's the reason why I don't want to lose it. I guess have no option but to move away from Public Mobile. Thanks for your help.
03-13-2017 08:21 PM - edited 03-13-2017 08:37 PM
03-13-2017 08:18 PM
Or can I add another number with same plan to my account. After that I can port out my original number.
03-13-2017 08:15 PM
Unfortunately, that's not possible, as porting a number out would immediately cancel the PM account.
