Double charged
JimBob
I was just charged to reactivate my phone because the visa debit card was not accepted.
everything was correct with the number.
I used a different card and it worked.
I was charged to reactivate
then charged to change my plan
i believe I was double charged
what can be done about this
why does the system reject cards that have previously worked fine?
Please any help is appreciated
aashray91
Hi there
Just wanted to know whether your problem resolved ?
I have a similar type of problem.
JimBob
Thanks I'll do that
hummuschips
Hi JimBob,
you should use the Get Help button above and fill out the contact us form to contact Public Mobile or try to private message one of the mods with your information and hopefully they can get it all sorted out for you.
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
