Can't Send or Receive Picture or Video Texts
OKJoy
Hi,
I just got a Samsung S7.  I can access data, voice and texts but I can't send or receive any multimedia texts.  Any help would be greatly appreciated!
OKJoy
Thank you for the quick replies and links!
I've set up the APN as per the Knowledge Base.
There were a few different suggestions for APN Type in the link SD08 posted, I tried several different configurations but nothing worked.
I'm using Samsung Messenger. I installed Android Messenger and tested it, but it didnt work either.
Chaos_Scorpio
have you tried a different txt app? what are you using now?
NDesai
You must have your data on to send and receive picture or video message. Make sure your APN settings are correct.
