How could refer a friend want't receive any msg notice?
situ
8 REPLIES 8
SD08
To be sure you are checking in the right place for your referrals, look here (be sure to click the little arrow to expand details):
When did your referral sign up to Public Mobile? Referrals can sometimes take a few days to show up in your account. If it's not there after a few days, then you'll need to contact a moderator to fix it. In that case, you should send them a private message with your phone number and the phone number of the person you referred. How to contact moderators:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Contacting-our-Community-Moderators/ta-...
situ
thankyou
steven930
if it is complete , both you and your friend will receive and text msg notice.
@situ  if you need to be certain and you don't see it in your account, you could check with a moderator to see if anything was applied to your account.
Though i doubt they would tell you iif your friend actually added it or not for privacy reasons.
situ
i had refer a friend before then receive a test msg notice but this time didnt
So you're saying your friend used your number s a referal?
I'm unsure if you receive a text saying that that referal has been complete.
But you should see it in your account.
situ
how come i had refer a friend, but didnt receive any texts notice on the phone
CaNuCk07
@situ  Can you please clarify what you are trying to say?
