plan change not working
TA
hi ... new here ... tried several times to change my plan from Canada wide talk to Canada -US but it's not happening... not sure what i'm doing wrong
1 REPLY 1
will13am
@TA, I can't tell what is going wrong without sitting next to you while you apply the change.  In any event, if you cannot do the change yourself you can always ask the moderator team to assist.  The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
