3 weeks ago
3 weeks ago
If you click on the Get support link what happens? You would need to engage PM directly. If the chatbot doesn't work, message them directly.
3 weeks ago
this is what we receive can u help
3 weeks ago
What is the error ? Are you porting your number from another provider? Did you use the public mobile app?
If it will not move forward, use the chatbot to contact public mobile. The orange circle at the bottom of your screen. Type customer service agent. If that still doesn't work use this link
