01-15-2018 01:46 PM - edited 01-04-2022 03:19 PM
I couldn't find it clearly - is it in okay taste to through a shout out to see if anyone has PM to refer us (we're four lines, coming over from Rogers).
PM me.
01-15-2018 02:02 PM
@timmmmeh, where are you there maybe someone here from your city. Your offer is very nice but please make sure to keep the 3 referrals for yourself
01-15-2018 02:00 PM
@srlawren, you aren't slow you are wordy lol/ your post was much longer I am not smart enough to use or even think of a big words lol
01-15-2018 01:57 PM
Thanks - I actually don't know anyone in my city that does use PM - so was going to through it out there, but to be politically correct I'm glad I asked.
01-15-2018 01:57 PM
@ShawnC13 I guess we were typing at the same time, and you beat my by 11 seconds! blast my slow fingers... 😉
01-15-2018 01:56 PM
@timmmmeh Good question. I'm not sure it's explicitly called out in the community guidelines but it's probably frowned upon. If there is anyone that has helped you make your decision to come to PM (no, I'm not asking!) then you could reach out to them via private message and ask if they'd like to give you thier number for the initial referral, but I dont' think I'd suggest offering it up publicly.
By the way, make sure that for your 2nd, 3rd, and 4th lines you give yourself the referral. You could either chain them, so use line 1 as referral number for line 2, line 2 for line 3, and line 3 for line 4, OR, you could give them all to line 1, etc. Whatever works best for you.
01-15-2018 01:56 PM
@timmmmeh, I am sure you have had many people message you about this opportunity you have proposed. If that is the case I would suggest maybe giving one referral and then adding the 3 other lines to a referral of the first plan you moved over. That way you are getting an additional $3 a month off of your bill.
