Refer-a-friend doesn't show up
bloom84
Hi,
I just went to a wall-mart to buy a sim card and activate the 30$/month plan.
The problem is I don't see the refer-a-friend reward even though the wallmart employee told me everything was fine. (I gave him the phone #)
How do I make this right ? thanks
It could be sooner. 🙂   Depends on when their system do their maintenance thing.
CalgaryBen
If you log into your Self-Serve portal, navigate to "Payment" and then "Transaction History", and then pick a suitably large time range (e.g. "Last 6 months") and then click "Search", you'll likely see your initial credit/payment, followed by "$10 Referral Credit/Crédit de recommandation de 10 $" (note that this is in descending chronological order, so you'll most likely see it at the top of the list once applied). As others have stated, this could take a few days. In my experience, it showed up on the day following initial activation (i.e. within 24 hours in my case).
@bloom84 wrote:
I'll post again if there is a problem in 72-hr ! thanks
I wouldn't post again if it hasn't shown up.  I would just directly private message the Moderator Team.
bloom84
I am the referred party.
Thanks, I didn't know about the 72-hr delay (didn't see it mentioned anywhere), thought it was instant.
ShawnC13
@bloom84 wrote:
Hi,
It takes upto 72 hours to see the $10 credit show up in your available funds.
will13am
@bloom84, are you the referred party or the one referring?  If you are the referred party, you will see the one time credit within 72 hours.  If you are the referring party, you should see the number of the friend who used you as referral in the rewards tab.  Your $1/30 day reward is applied at each renewal.
