Re: We want to hear from you: technical concerns, glitches, or bugs
Tersla
I have had several issue moving from Sasktel. Issues porting my number and issues with incoming calls reported as not in service or going direct to voicemail.
1 REPLY 1
Is your Sasktel service still working? If it is, that means that porting was never finished.  When someone calls you and it goes to voicemail, is it the voicemail from your old carrier?
