Overcharged
awalker85
I've been overchaged on my credit card charged 56.50 and 7.91 and another 56.50 for the 50 dollar plan. Can anyone fix this ???
2 REPLIES 2
awalker85
Thank you very much! I'm aware there is tax added on which I of course have no problem with it's just that I was charged in total 120.81 for a 50 dollar plan. I did use your link and sent them a message. Thanks again so much for your help.
will13am
@awalker85, $50 is the pretax amount.  Tax is added on top of this.  If you have been double charged, then you will need to contact the moderator team to get that reverse.  The moderator team can be reached via private message using this link.  Refer to the following knowledge base link for information on contacting the moderator team.
