3 weeks ago - last edited 3 weeks ago by computergeek541
I registered an ESIM for my cousin who just came to visit. When activating the esim i used my phone so it connected to my phone- eventhough i use his phone IMEI to check for compatibility. I got confused and accidentally deleted that esim. Afterward, i had purchased a new esim, but wasn't able to activate, and it said contact the Public Mobile Agent for help. Please help me. They already charged me for the plan and esim card but still not able to use
🥲 @Hieu8
3 weeks ago
You have to contact customer support and they may make you buy a physical SIM card to active the account, then they can assist you in switching to a eSIM.
3 weeks ago
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
