Network not linking to phone.
BalejaFamily
New in Town / Nouveau en Ville
I set up a brand new PM account to a brand new phone and it is not connecting. Compatibility is good and SIM card is activated.
geopublic
@BalejaFamily  A couple of questions:
  1. Did you activate at the store or online?
  2. Is it a new number or are you porting from another provider?
  3. What is your PM plan?
  4. What is the make an d model of your phone?
Thanks!
popping
PM does not support GSM(2G) signal.
Which phone are you using?
If you phone support GSM and none other signals, it will not work with PM.
Your message/thread has been moved to the Getting Started category.
Can you tell us the model of your phone?
