MMS not working on Samsung J6
S_Ayquipa
I signed up for PM three days ago, activation went through, but my Samsung Galaxy J6 is not receiving or sending MMS. I have checked and rechecked APN settings, and all seems correct. I have cleared all my Apps caches. I tried downloading gosmspro to route messages through that app, and while it received a MMS, it still would not actually download the content. I don't know what else to try! Please help!
10 REPLIES 10
S_Ayquipa
For sure! Here's the APN default settings that are working for my Samsung:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
@S_Ayquipa wrote:
Thanks for your reply, I ended up getting some help from a Mod... finally working! 🙂
@S_Ayquipa  Thanks for letting us know. Care to share the special APN from the mod team?
S_Ayquipa
Thanks for replying... this post didn't work, but finally got it working... 🙂
S_Ayquipa
S_Ayquipa
I got some help from a Mod, after trying all these things we reset to default APN, nothing like the suggested APN link, and now it works! So frustrating. Thanks for trying to help!
@S_Ayquipa wrote:
Thanks, still trying...
Do you have a valid data component in your service to see if it otherwise works?
Are you able to post screenshots of your APN settings?
S_Ayquipa
Spoiler
Tony8
Hi, Your Data connection has to be on. Also you may have to check your APN settings again, mine had a typo. 😞   Hangouts may be a better way to send photos.  I hope you get it working.
I'll just cover the obvious...whether or not you have data in your plan, data mode needs to be on.
Other than that as with the link provided above and:
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Pizzaeh
See if this post by @Ramshackal helps...
https://productioncommunity.publicmobile.ca/t5/Discussions/Can-t-send-or-receive-MMS/m-p/67317#M1705...
