12-28-2019 01:19 PM - edited 01-05-2022 08:44 AM
Is an LG-703 cellphone compatible with Public Mobile? Does not show on the listings, bought it in 2017.
12-29-2019 04:03 PM
Public Mobile is Telus.
@lefty4666 wrote:Thank you, looks like this might work. Have you had any issues with area coverage, ie, do these folks use Bell or other major tower systems?
12-29-2019 03:58 PM
12-29-2019 03:55 PM
Thank you - excellent link
12-28-2019 01:37 PM
This phone should be compatible. I have the LGQ6 from 2018 and there are no issues. A mobile retailer could check it by using a PM sim.
12-28-2019 01:32 PM
Yes, it should work just fine, at least according to this:
https://www.frequencycheck.com/compatibility/KryDIay/lg-m703-q6-lte-a-32gb/canada
