How to port number form petro canada?
Michael999
How to  port  number form petro canada? Thank you!!!
Kingpong
According to Petrocan Mobility's website (https://mobility.petro-canada.ca/support-number-portability.aspx), you need to provide Public Mobile with your Petrocan Mobility's Account password/PIN and Phone IMEI.  Your Petrocan Mobility account will not have an account number.
"Porting your Petro-Canada Mobility number to another service provider
What information do I need to provide the new service provider?
  • Account password/PIN
  • Phone IMEI (HSPA/GSM) devices
Your new service provider will contact us to release your existing Petro-Canada Mobility number and your account will be cancelled. Any remaining balance you have on your Petro-Canada Mobility number will be forfeited.
To reactivate a Petro-Canada Mobility Number, you need to purchase a SIM card."
kav2001c
@Michael999 & @NDesai I actually disagree with that other post
(I ported two 7-11 lines as well)
Do NOT use PIN
You are far better off to use your IMEI number (assuming your line was active and in use)
7-11 has no account numbers either; we just put cell number in account box as a placeholder if required. It has no positive or negative effect on your port.
But do select a temporary Public number then port in 7-11 number as a change
Mana
@Michael999
If you are thinking of joining PM, you may wanna read about this promo offer:
https://productioncommunity.publicmobile.ca/t5/Announcements/Competitive-Response-Limited-Time-Offer...
Thanks
mimmo
we often reccoment that you create the new number (temporary) then once your service is working you port your number.
you need your account name exatly, account number  and your phone numbber of course
and the consensus is that you click i am authorised before you enetr your info.
Michael999
Thank you so much ! I will try later Man Very Happy
NDesai
Here you go: https://productioncommunity.publicmobile.ca/t5/Discussions/Petro-Canada-Mobility/m-p/108360/highligh...
