Help sending International SMS
luceo
Am trying to message my nephew after his dad died, trying to message UK, have area code for the region he is in 01474. Have tried diallin 011-44-1474-number like I would if calling but text is failing. Any help would be GREATLY appreciated , we really need to be able to talk. 😢
luceo
Nope got this back:
You’ve entered an incorrect number. Please try again. Vous avez entré un numéro incomplet. Veuillez réessayer.
luceo
Got a text back saying this; You’ve entered an incorrect number. Please try again. Vous avez entré un numéro incomplet. Veuillez réessayer.
will13am
I have sent SMS to a friend in the UK.  I used 011 44 xxxx... and it worked fine.  Maybe try a different SMS app.  I used the stock google app.
matbasm
@luceo, have you tried simply '+', the country code for UK, then the number with area code.  Another provider's web site indicates that is the proper format for LTE.  Not sure if it is specific to that carrier (VM) though.
wetcoaster
Sorry for your loss.
Have you tried +44 1474?
(That format works for me on the stock messaging app and Textra.)
