Change of Number Failed
amingley
Hey,
I originally set up my phone in the Toronto area, but have no moved to British Colombia. I attempted to change my number this morning, but all I get is a failed message. Someone else was having that problem but it was because they were trying to change it more than once in a 30 day period. However, I have never tried to change the number before.
Any help would be much appreciated. Thanks!
1 REPLY 1
Someone_here
You can try using another browser, or using incognito browsing... if it doesn't work, then you can contact @CS_Agent by sending them a private message with your information and help needed.
