11-25-2016 07:15 PM - edited 01-04-2022 01:17 PM
Hello:
I don't want to transfer an existing number but the 'drop-down' for area / city on the 'select new number option' does not work - so I tried the transfer option but get the error message above.
Can't create an account as I don't yet have a phone number.
Basically, as a new customer with a new sim card, I can't do anything. 😞
Any help would be appreciated.
Rob.
12-13-2016 03:22 PM
Someone replied me and the trick is to shorten the name when activating. So simple! Why don't they just say this here in the community??
11-30-2016 09:13 PM
I'm having the same issue and no Moderator replies any of PM.
11-25-2016 09:38 PM
hi
what i noticed when i activated my first line was if you try to fix an error the program get stuck, i also noticed that the main info stays , and it is a bad idea of clearing cache, i just keep trying till it when thru, under normal circunstances the proper way is cleaar cache and re do the info , but with PM it has to many bugs, like if your are inputing something and you have to deleted it will get you stuck, after i activated 2 more lines making sure i don't have to delete any thing and the process when thru smootly.
when i cleared the cache and try to re do it , i got the error msg invalid sim
11-25-2016 07:29 PM
Yes, even tried linux.
11-25-2016 07:25 PM - edited 11-25-2016 07:25 PM
Tried alternate web browser? Clear cache?
